Building up a head of steam! `88 SETA Sedan refresh
  • kingston
    • Jun 2010
    • 2669
    About 9 months ago, I was out for a walk and found a 1988 325 Sedan in Schwartz over blue cloth in my neighborhood. There was a 'for sale' sign on the car, but no phone number. Several days of stalking the car yeilded a 'chance' encounter with the owner, who was selling most of his possessions due to serious legal troubles & subsequent expenses.
    Asking price for the car: $1,700. My purchase price: $1,200.
    The car as it was when I first bought it...
    The good news was that the previous owner had been trying to restore the car, and had put in a new battery, fuel pressure regulator, Guibo and some fuses. Most importantly, Manual Transmission.
    The bad news was more plentiful. No A/C (still set up for R12), paint is roached, crack in dash, front passenger side window doesn't budge. Also, some PO had installed a fuel pump from a 318, which could not keep up with the demands of the 6-cylinder M20B27 engine.
    So, I've done a few things to the car, none of which really warranted a thread of it's own. At this point, what I've done is:
    * Replace the 2 front blue cloth comfort seats with Heated Black Leather
    Sport Seats from a 'Vert.
    * Replaced the standard 4-spoke City Bus-spec steering wheel with a
    tasty MOMO wheel, with an authentic BMW horn button.
    * Replaced the fuel pump with the correct model, fuel filter, spark plugs,
    air filter.
    * Painted the windshield wiper arms, DB bumper trim and grills.
    That was phase 1, but I was just waiting for my Bonus check to get serious...
    Originally posted by LJ851
    kingston is the play by play announcer for this thread.
    ‘Tis by the grace of God that my cars run!
    Originally posted by unloadedak
    #teamross
    Siobhan's Build Thread - UPDATED!
  • kingston
    • Jun 2010
    • 2669
    Next up was ditching the bottlecaps.
    I picked up a set of BBS RX wheels in 17x7.5 size, powder coated gold. These used to belong to MR325, who sold them to Levent at Guten Parts. Levent, BTW, has lived up to reputation for being all-around awesome! He's helped me track down some parts I wanted, given me very fair prices, and steered me to others when he felt they could give me better prices than him!
    Levent also supplied the MOMO steering wheel. Ebay supplied the MOMO hub.
    #teamross
    • kingston
      • Jun 2010
      • 2669
      Meanwhile, I've been collection parts for the "327i" swap...
      But the big refresh had to wait until I got my end of the year bonus:
      Bushing Set for Rear Trailing Arm, 2 Bushings Per Set 2 33-32-9-061-945-M10
      Rear Subframe & Diff Bushings, AKG Urethane, 3 piece 1 #SFDS30
      Control Arms 2
      Offset M3 Bushings (press into powder coated 'eyes')-Pair 1
      Powder coated 'eyes' (with m3 offset bushings pressed in) 2 GPS Custom - Red PC
      AKG Re-enforced Rear Shock Mounts - Pair 1 #RSMP30
      Front upper strut mount 2 31-33-1-139-452-M10
      Tie Rod Assembly 2 32-11-1-125-186-M69
      Lock Plate for Tie Rod to Rack 2 32-11-1-124-540-M9
      IE 22mm front/19mm rear Sway Bar Spec E30 1 Ireland Engineering
      Water Hose, Thermostat to Heater Valve/Outlet 1 11-53-1-289-377-M101
      Water Hose, Thermostat to Water Pipe 1 11-53-1-718-982-M101
      Water Hose, Thermostat Housing to Throttle Housing 1 13-54-1-719-966-M101
      Water Hose, Water Pump to Thermostat Housing 1 11-53-1-287-651-M101
      Water Hose, Throttle Housing Small Hose 1 13-54-1-719-967-M21
      Water Pump with Gasket (uses metal impeller) 1 11-51-9-070-759-M52
      Radiator Mount, Upper, 3 Series 2 17-11-1-117-442-M9
      Radiator Mount, Lower, 3 Series 2 17-11-1-178-412-M200
      Belt, Alternator 10 X 965 1 11-51-1-469-236-M21
      Belt, Power Steering 10 X 825 1 32-42-1-469-239-M21
      Belt, A/C Compressor for Wing Cell Compressor 1 64-52-1-466-043-M21
      Head Gasket Set, 325i/is/iC/iX (1987-91) 1 11-12-9-059-240-M30
      Ignition Rotor (Bolt-on Type) 1 12-11-1-734-110-M18
      Distributor Cap 1 12-11-1-725-070-M18
      Ignition Coil 1 12-13-1-286-087-M14
      Ireland Engineering High Perf red wires 1 12-12-1-720-529-M106
      BMW E30 325i tachometer 1
      Timing Belt & Tensioner 1
      LSD 1 3.73LSD
      Door Panel Clip, lower 10 51-41-1-922-138-M9
      Door Panel Clip, upper 10 51-41-1-922-137-M9
      Euro Hella Smoked Headlights 1
      New High Beam Caps 2
      Used Hella High Beam 1
      Bulb Holders 12
      Cylinder Head Bolt Set, (14 Bolts Per Set) 1 11-12-1-726-478-M17
      Starter 1
      Exhaust Hex Nut, copper 12 18-30-1-737-774-M58
      Genuine BMW Part: Stud Bolt 6 11-62-1-716-870-BOE
      Exhaust Flange Stud to Header Pipe, 10 x 35mm 6 11-62-1-711-671-M9
      Rubber Intake Boot 1 13-71-1-726-325-M604
      New Half Shafts with bolts and washers 2 33 21 1 226 901
      Total: $2,992.65
      Levent has ordered the above parts.
      I'm ordering Billstien Sports and H&R Sport springs Tuesday or Wednesday of this coming week.
      I will take many pictures as I go!
      #teamross
      • kingston
        • Jun 2010
        • 2669
        Got the first little batch of parts today! AKG diff bushing and subframe bushings showed up.
        LOTS of other parts on the way, including a minty dash, and (soon) plastic bumpers and hardward.
        WOOT!
        #teamross
        • kingston
          • Jun 2010
          • 2669
          Big updates!
          WOOT! Big delivery of parts!!
          Most of these parts came from Levent at Guten Parts. The only thing there that didn't was the set of H&R Sport Springs, and that was because Levent told me that Turner was able to offer the springs cheaper than he could.
          While I'm on the subject of Levent, I want to post publicly how awesome he has been to deal with. I had seen him posting on the board, started chatting with him, and began to buy a few little things here and there from him. Then came the BBS wheels, and then TONS of other stuff.
          The main point I want to get across is that everyone seems to know Leven/GutenParts for the Euro parts, and other hard-to-find rare items. The great thing is that Levent actually is one of the best places I've EVER found for one-stop shopping. I picked up all the water hoses, ignition parts, rubber hoses, starter motor, shocks, half shafts, 3.73 LSD, etc, etc, etc from Guten Parts, and everything came in quickly, packed well, and with very fair prices. I used to get all my parts from PelicanParts, but I'm a Guten Guy for life now!
          Levent, thanks for being great to work with! :D
          #teamross
          • kingston
            • Jun 2010
            • 2669
            Ireland Engineering swaybars showed up! Now I need the IE wire set, some SS brake lines, and E36 steering rack, plastic bumpers and a few other odds & ends, and I'll be ready to dig in!
            #teamross
            • kingston
              • Jun 2010
              • 2669
              Work done! Well, on the suspension anyway...
              I still want the front to be lower...
              Loving the Smoked Euro smilies!
              Two of the best mods I did! ZHP knob and the MOMO steering wheel.
              More to come!
              #teamross
              • ck_taft325is
                • Sep 2007
                • 6880
                Very respectable start to this one. I browsed pictures more than text so what are the plans on the DB's? Keep 'em or going... ?
                Need a part? PM me.
                • alB5
                  • 785
                  Looks great, I can't wait to get to work with Levant. I need me some engine/suspension/body parts lol.
                  1991 318is -> 2004 R32 -> 2002 Jetta TDI -> 2014 FiST
                  No E30 Club
                  • trackjunkie21
                    • Jan 2010
                    • 3962
                    Dude, that's awesome! Needs some drophats in the front. Looks awesome otherwise.
                    Originally posted by Wh33lhop
                    VANOS: sometimes you just need to go full retard.
                    • kingston
                      • Jun 2010
                      • 2669
                      I'm going with plastic bumpers. Had a line on some, but that dried up.
                      Thanks! Yep, drophats are definitely on the agenda!
                      Yeah, Levent is da MAN! You're going to have a blast working with him. Not only did he get me some really cool parts, but he also got me great prices on everything. He's a heck of a guy, too! I highy recommend Guten Parts, and he's the ONLY guy I'll buy from!
                      I can't wait to post pics of the next round of stuff!! On it's way from Levent now!
                      #teamross
                      • drutt23
                        • Feb 2011
                        • 392
                        Looks good man. Keep it up!!
                        1989 325i|1992 325i|And completely obsessed|:woowoo:
                        sigpic BMW. The Ultimate Driving Machine.
                        The Build...
                        • kingston
                          • Jun 2010
                          • 2669
                          Thanks, man! Next up on the agenda is to drop the rear subframe, and replace the bushings, half-shafts and pop on the 3.73 LSD!
                          Levent just shipped me a ejnight/Race Skids skid plate, front Zimmerman rotors and a black pedal set from BMWpedals.com. WOOT!
                          #teamross
                            • 37833
                            Man I loved those wheels, don't change the color!
                            I really like your car and what you're doing with it.
                            Grover Beach, California
                            BimmerHeads.com
                            • rares
                              • 730
                              yes i agree, this is a good build.. very nice stuff
